Discussion topic: Sky q not working
This message was authored by: debbyj
Sky q not working
Yesterday we had no satellite signal but could watch recordings, download and use apps. Tonight there is nothing already booked an engineer for next Friday 20th but not sure can cope with that any suggestions? Sky broadband is working benn through turn it off and on etc
Re: Sky q not working
@debbyj  Sky Q needs a satellite siognal to keep the bpx alive, without opne it will eventially stop working.
There is no work arounds to get on demand back. Turning your broadband off & on ill have zero affect
Avatar for debbyj
Thank you so the information that Sky provide ie you will still be able to view recordings, apps and on demand is incorrect
so we have a week without access to an expensive service ☹️
@debbyj Sky Go will still work in the meantime.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for debbyj
Yes but as Sky doesn't work with Chromecasr that isn't the easiest option
@debbyj if you have a laptop with a hdmi output then connect that to your TV by hdmi
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
