3
This discussion topic has been answered Discussion topic: Sky q multiroom box/remote
This message was authored by: Simmykb
All of a sudden iur remote won’t work. Changed batteries. Nothing. Rebooted everything. Nothing. Any help please?
Re: Sky q multiroom box/remote
Hi @Simmykb
Hi @Simmykb
Avatar for Simmykb
Thank you so much. All sorted 🙂
Answered - Go to Answer
