Discussion topic: Sky q mini
Message posted on 22 Oct 2024 11:39 PM
Sky q mini
After connecting the sky q mini box upstairs to the downstairs main box it works for approximately 5 minutes before a blue screen appears stating a problem finding the sky q box on the network. Restarted the whole thing several times and retried several times only to be left with the same issue (ERROR:MR204)
Only started since switching to fibre from sky
Message posted on 23 Oct 2024 07:15 AM
Re: Sky q mini
Hi @Adam175 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Message posted on 23 Oct 2024 08:52 AM
Re: Sky q mini
When you were using a sky router the mini could connect direct to the router wifi to get to the Q
Now you're on a 3rd party it can't and it has to talk direct to the Q. Which has a terrible wifi signal by comparison.
A sky Q booster can help, positioned between the two boxes, or use powerlines or ethernet.
Message posted on 23 Oct 2024 08:08 PM
Re: Sky q mini
I have tried everyone's advise in resetting/rebooting and the sky q boxes simply won't connect by Wi-Fi to the new sky fibre router. I can connect the main sky q as a wired connection but not the mini box making it unusable at the moment , any time I do get it to connect it looses all signal in minutes
Message posted on 23 Oct 2024 08:16 PM
Re: Sky q mini
@Adam175 what colour is the Sky router that you were provided. If its the new Max router the white one then you need to connect the mini box directly to the main box by wps. This because the new max router does not connect to the Sky mesh like the older back routers did.
If you are having disconnetion problems between the mini and main box you may need a Sky booster.
Message posted on 23 Oct 2024 10:28 PM
Re: Sky q mini
A possible simple but not free route for you is to connect the Q mini box to the router via cat 45 cable, you will need something similar to this:
TP-Link AV1000 Powerline Starter Kit
466/1847
It not the same one I used for a few years till I moved but these thing do a great job, and don't consume any of your precious Wi-Fi
Message posted on 25 Oct 2024 08:12 PM - last edited: 25 Oct 2024 08:13 PM
Re: Sky q mini
We're up to cat 45 already?! Feels like only months since cat 7 was state of the art 😉
