This discussion topic has been answered Discussion topic: Blue screen
Message posted on 26 Oct 2024 06:52 AM
Can only get the blue screen on our mini box, it displays the full menu and settings but not getting the actual channel
Message posted on 26 Oct 2024 09:35 AM
Hi @hogan12861
Reboot the mini as above.
Hi @hogan12861
