Discussion topic: Sky q mini won’t connect
This message was authored by: zionscion
'There has been a problem finding your Sky Q box on the network'
I've just changed modems, everything is working fine on my main box, the mini won't connect. Have tried the various restarts and resets, still nothing. Help!
Avatar for zionscion
Level 0 icon
Re: Sky q mini won’t connect
Also, error MR104
@zionscion wrote:
Also, error MR104
Hi @zionscion
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
