18 Apr 2023 07:34 PM
Mains power was off for few days when went away, came back & both our Samsung TV won't come off standby and sky q mini box now won't either?
18 Apr 2023 08:14 PM
Hi @ChaCha79
Regarding your Samsung TV try a reboot..
Disconnect power lead for 30 sec and then reconnect.
For the Q box check through the following link
08 May 2023 06:43 PM
Hi, TV still not working so now tried using sky q mini box on a different TV... problem still there & it won't come off standby, have tried many times all of the power off / reset button / power on and I'm not getting any flashing red or green lights! Reading the sky guide it says we might now need new mini box but can't afford that! Any help?
08 May 2023 07:52 PM
Hi @ChaCha79
If you have completed the following Recovery procedure and cannot solve your issue then the Mini needs replacing.
As all Q equipment is rented replacement is at Sky's responsibility and will be free of charge.
Contact Sky for replacement.
If the lights don't show after 30 seconds, repeat steps 1 to 2. If it still doesn't work, you might need to replace your Sky Q box.
Most features will work straight away, but some can take up to 5 minutes.
08 May 2023 07:58 PM
@ChaCha79 if you need to replace you mini box Sky will replace them frre of charge this is because all Sky equipment is loaned to you so Sky are responsible for replacing it but it must be returned to them when you leave Sky
