Discussion topic: Sky q mini will not show recorded programs
Message posted on 24 Jul 2024 02:36 PM
Reconnected sky q over ethernet to vodafone router and connected mini over wireless to vodafone router, i can watch live tv but not any recorded programs
Message posted on 24 Jul 2024 06:38 PM - last edited: 24 Jul 2024 06:40 PM
Re: Sky q mini will not show recorded programs
Hi @Delia69
On 3rd party Broadband you can only connect mini to the main Q box when using WiF.
Reboot the mini as above.
Edit
Just be aware that the Main Q WiFi cannot be turned off as it is needed to connect the mini on 3rd party broadband.
