Discussion topic: Sky q mini only working for apps
Message posted on 18 Aug 2026 05:55 PM
I have 3 sky q mini boxes connected to 1 sky q main box. 2 of the minis are working fine, 1 of them shows sky but it is freezing on and off with audio on and off, meanwhile all of the apps work perfectly. I do not have any error messages.
Message posted on 18 Aug 2026 06:11 PM
Re: Sky q mini only working for apps
@Heavyheart couple of thingsto try
Have you tried rebooting your main Q box ie
then
reboot the mini that has the problem
If that doesn't help
can you try swapping one of the working mini with the one thats not working as it may be a distance problem
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
