Discussion topic: Sky q mini connectivity issue
This message was authored by: Beardedgardener
We've recently got sky q mini for my daughters bedroom.  During setup we get the code Error:MR102
There might be a problem with the connectivity in this area of your home. You might need a sky Q booster.
In terms of WiFi we have a signal in this room but sky says we don't ?
Any help greatly appreciated. If I do need to get a booster where do I buy from ?
Re: Sky q mini connectivity issue
Hi @Beardedgardener
Reboot the mini as above.
