Discussion topic: Sky q mini boxes
Message posted on 09 Jan 2024 05:29 PM
Sky q mini boxes
My sky q box stopped recording etc and in the end would just say please wait.
I have reset hard drive and lost all my recordings but it seems fine now and very quick at downloading BUT my three mini boxes keep freezing and says "you can't currently watch tv as there is an issue with connectivity between this mini and q box"
I have checked everything and it's still doing it every couple of minutes. Help!
Message posted on 09 Jan 2024 05:46 PM
Re: Sky q mini boxes
I have reset hard drive and lost all my recordings but it seems fine now and very quick at downloading BUT my three mini boxes keep freezing and says "you can't currently watch tv as there is an issue with connectivity between this mini and q box"I have checked everything and it's still doing it every couple of minutes. Help!
Hi @Mattdeb2023
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the mini. Start with the mini nearest to the main Q box.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If the afirst connected mini is nearer than the main Q box you can also use this for the WPS on the second mini.
Message posted on 09 Jan 2024 09:18 PM
I've managed to sort two out but one is still saying it looks like there is no internet connection etc.
I have just downloaded a program and watching it on the mini box I've fixed but it keeps freezing every now and then for a couple of seconds.
I feel the main box might need replacing!
Message posted on 10 Jan 2024 08:11 AM
Quite possibly although it might also have decised to use a different link to connect to the Q box via the wifi mesh when it all got reset and disrupted. Moght be worth a network reset on it and forcing it to WPS connect via whichever box you think works best.
Message posted on 11 Jan 2024 08:59 AM
I have a new box coming today as the mini boxes will not play any thing now saying connection problem. The main box although can watch live I will not go on uhd.
so it's had it.
thanks for the help though.
Message posted on 11 Jan 2024 09:44 AM
so it's had it.
@Mattdeb2023 if it's coming by DPD they will expect you to gave your old box ready to swap for the new box remember to remove your viewing card
