Discussion topic: Sky q mini boxes problem
Message posted on 01 Jan 2025 02:30 PM
My sky q mini boxes won’t connect to my main sky q box after a power cut
Message posted on 01 Jan 2025 03:22 PM
Re: Sky q mini boxes problem
@Coral+Gillespie Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 Jan 2025 03:49 PM
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the reset button.
Message posted on 01 Jan 2025 04:31 PM
Thank you very much for your help. It worked!
