Discussion topic: Sky q mini box
Message posted on 09 Oct 2025 07:29 PM
							Sky q mini box
I have multi room. One of the mini boxes had a picture and no sound. Now it's stuck on a setting screen and will not adjust. It's just stuck with a blue screen?
Message posted on 09 Oct 2025 07:35 PM
							Re: Sky q mini box
Hi @Lee1311
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If your mini is still stuck and will not respond to the remote
Reset your mini remote by pressing  and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes.   However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to get the accessible screen
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Message posted on 09 Oct 2025 08:06 PM
							Re: Sky q mini box
Thanks, that got the picture back. But still no sound
Message posted on 09 Oct 2025 08:08 PM
							Re: Sky q mini box
Message posted on 09 Oct 2025 08:23 PM
							Re: Sky q mini box
Didn't think about resetting the tv as you could watch you tube and things on it 🤦♂️
thanks! 👍
Message posted on 09 Oct 2025 08:25 PM
							Re: Sky q mini box
