Discussion topic: Sky q mini box
This message was authored by: Dave652
Sky q mini box
Can you connect a sky business connect router to a sky q mini box and if so how???
Re: Sky q mini box
Hi @Dave652
The Sky Q mini box can only be used on the same network as the main Q box.
Re: Sky q mini box
@Dave652
Q Television may or may not work behind a Sky Business Hub: in most circumstances such a Hub wouldn't be appropriate in a location where Q television is in use.
As @oldfella indicates, the main and Mini boxes have to be on the same logical data network.  I'm not certain the Business Hub has a WPS button.
