Discussion topic: Sky q mini box won't switch on
This message was authored by: Ron52
Mini box won't switch on
Re: Sky q mini box won't switch on
Hi @Ron52
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the minibox on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
