4
This discussion topic has been answered Discussion topic: Sky q mini box won’t move off amber light
This message was authored by: JueH
Hi my sky q mini box is stuck on amber, can't use remote nor buttons. Have tried all self help guides but no luck, including checking remote and turning off at mains . Any help appreciated
Re: Sky q mini box won’t move off amber light
@JueH wrote:
Thank you , I have tried to pair to main box, the light now goes green however it's not connecting . Can't get to set up and remote won't work, help appreciated
Hi @JueH
If you have a green light on your mini and you are sure that the HDMI  TV input on the TV is set correctly for your Q box.
First try Try completly resetting your Bluetooth remote.
Then try pressing
Home 1 0 8 0 Home
on the mini remote.
This will set the mini to 1080i resolution.
If the mini responds make sure that you are pointing the remote at the mini and re pair the remote by pressing 1 & 3 together and follow onscreen instructions
This message was authored by: Mr+Flibbles+86
Avatar for JueH
Hi @JueH
Then try pressing
Home 1 0 8 0 Home
on the mini remote.
Avatar for JueH
Oh my it's worked !! Thank you so so much
