Discussion topic: Sky q mini box not working
Message posted on 04 Aug 2025 12:48 PM
One My sky q mini box is not working I've tried a lead from another box and that does not work either I need a replacement please
Message posted on 04 Aug 2025 12:53 PM
Re: Sky q mini box not working
Hi @Val671
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue,
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 04 Aug 2025 01:40 PM
hi there I can't seem to get my sky working at all. Also the Wi-Fi is really weak. It don't even reach my ring doorbell
Message posted on 04 Aug 2025 01:41 PM
hi there could someone phone me please? This is getting quite frustrating. I seem to be getting nowhere. I've got no sky TV and my Wi-Fi is really weak. I've already paid for it
Message posted on 04 Aug 2025 01:50 PM
As already posted in this thread you are not contacting Sky directly here as this is a customer forum.
To contact Sky
