Discussion topic: Sky q mini box not working
Message posted on 26 Nov 2024 07:45 PM
Hi all am a penisior who recently upgraded to sky q with mini box. Mini box worried two days after installation a month ago hasn't worked since iv rang an rang sky with no avail I can't get speaking to someone but when I do can't understand a thing can any1 help. When I plug box in it just goes blank screen
Message posted on 26 Nov 2024 07:46 PM
Re: Sky q mini box not working
Hi @Fifi1822
Reboot the mini as above.
