Discussion topic: Sky q mini box not working
Message posted on 05 Jun 2023 09:57 AM
I've had Sky Q and multiscreen now for a while. The mini box has now decided not to work, it just says Programme Unavailable. When I check settings, it says all connected both on the mini box and main box. I have got multiscreen so that's not the issue. Tried all the usual reset options but nothing has worked. I'm able to watch the apps connected to the tv (neflix etc.) but not the channels on the tv it says please check your subscription entitles you to view this channel but I know it does. Any help would be much appreciated.
Message posted on 05 Jun 2023 10:21 AM
Re: Sky q mini box not working
Hi @Daryl1987
On the main Q box have you tried a Reset Settings in the Q box hidden menu.
