Discussion topic: Sky q mini box network name,
This message was authored by: hammerjeff
Hope you can help everyone,
Today one of our three mini boxes wouldn't connect to the main box.
For context I have a Smarthub 2 with a Bt complete wifi disc.
Turning it on brought up one of 3 questions,is this the first time setting up this box,have you changed router and one other,can't remember it to be honest,answered no to all three.
Next message says I should reset my broadband.So checked the other two mini boxes and they were fine as was everything else.
Decided to do a network reset on the mini box and noticed that the network name was a Sky WiFi connection.
Checked the main box and other two mini boxes,network name was our router.
Question is why was this Mini showing a sky network name,was it the Sky mesh ID,and why did it happen.
Network reset got it up and running by the way,did a wps with the nearest mini box.
Asking so it doesn't happen again.
Many thanks.
Re: Sky q mini box network name,
Many thanks.
As you are with BT & not SKY  the minis do not connect to your wifi but a wifi signal generated by the SKY Q Main box - hence it showing the SKY Wifi name
I am not sure why the other minis show your own Network name but  they are connecetd to your Main box wifi - others may know the reason but it does seem a quirk that the name can show that way
Avatar for hammerjeff
Level 5 icon
@nigea99  This is what I don't understand,the mini boxes are not connected to the router as they connect to their own mesh so why are they showing my router ID,not a Sky one,it's always been like this for 3 years and I can't tell of the problems we've had overall with WiFi both fttc and fttp
