Discussion topic: Won’t connect to wifi
This message was authored by: Gavlar81
Out of the blue the sky Q box disconnected from our WiFi. We don't have the sky internet.
We have followed the usual process of attempting to reconnect the Q box back to the same internet, but with no luck.
it keeps coming back with the error
! Unsuccessful connection. Please check your password and try again.
The password has not changed and is connected to everything else with no issues.
We have tried the reset/unplug process with no resolution.
anyone else got any advice on what to try?
Re: Won’t connect to wifi
Hi @Gavlar81
Assume you are carrying out a Network reset on the Qbox and entering SSID and password for your router 2.4 Ghz band?
Avatar for Gavlar81
Hello,
yes we have done a full reset on the router also.
All other devices connect without any issues?
This is around the stage of the process I decided to give up on the Q's wifi.
