Discussion topic: Sky q mini box keeps buffering
Message posted on 04 Jun 2023 06:59 PM
Watching Netflix and Amazon keeps buffering
Message posted on 04 Jun 2023 07:29 PM
Re: Sky q mini box keeps buffering
Hi @vickypet
Reboot the mini as above.
If the mini is still buffering try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
