Discussion topic: Sky q mini box has no volume
This message was authored by: Tilly+minx
I have changed hdmi cable and swapped it with another mini box so its not the tv its the sky q mini box
Re: Sky q mini box has no volume
Have you tried restarting it by switching off at the plug for a minute?
Avatar for Tilly+minx
Yes been completely disconnected for 2 days  tried it again tonight. Perfect picture but no volume 🙄
hi @Tilly+minx
A couple of things to try, although they may not be sucessful, I think worth trying
Firstly go to
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
and change the setting to Normal  - if it already is change to Dolby Digital and come right out & then go back & change back
If that doesn't work -  I know this is a very long shot but I  still think worth trying (even though a different mini worked) is to completely power down the TV (unplug or swiitch off at the mains) and then re-apply power
Home - Settings - Setup - Audio Visual -Picture Resolution
