Discussion topic: Sky q mini box disconnecting
This message was authored by: DaniB287
Hi since having my new internet installation with yourselves my sky box disconnects every couple of days if not daily and needs resetting each time.
Re: Sky q mini box disconnecting
Hi @DaniB287
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Avatar for DaniB287
Thank you, I'll give it a go ☺️
