3
This discussion topic has been answered Discussion topic: Sky q mini box connection issue
This message was authored by: TannyJ
Hi I have a main sky Q box and a mini box. I have recently changed my BT hub and have reconnected both boxes to the new hub. The main box is fine but the mini box works when I initially reset the network on it but still says it's not connected to the sky q box. When it goes into standby mode overnight the next morning it just says not connected to the sky q box and I have to reset it all over again.
When it asks me to press WPS on sky box is this referring to my main black sky q box or the white booster I have ?
Avatar for TannyJ
This message was authored by: TannyJ Answer
Re: Sky q mini box connection issue
Thank you so much for your advice. It turned out that the booster had disconnected from the main sky q box so the mini box couldn't connect . All sorted now 😀
This message was authored by: ThePope27
Either work, try both see which one performs better.
Have you changed the Sky Q main box and the minis standby mode from eco to active ? You can do it by going to Home > Settings > Setup > Preferences > Standby mode. Change it to active to stop it going into low power mode as Sky Q Mini doesn't play nice with 3rd party internet service providers, especially when standby mode is in eco mode, I've seen reports of it not waking up etc.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
@TannyJ which ever is the closest to your mini box if thats the white booster then connect it to that and the white booster should be connected to your main box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for TannyJ
