1
This discussion topic has been answered Discussion topic: Sky q mini box cant get channels protected error
This message was authored by: Sneakypete
My sky q mini box can't get sky channels or recordings but I an get apps ie prime.
Tried a reboot and wifi restart
This message was authored by: nigea99 Answer
Re: Sky q mini box cant get channels protected error
hi @Sneakypete
The mini boxes get their feeds from the main box thus:
The first thing is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on each of the mini boxes.
hi @Sneakypete
Wait at least 30s
