Discussion topic: Sky q mini box blue screen
Message posted on 20 Oct 2025 09:20 PM
Sky q mini box showing a blue screen on every chanel, even after rebooting many times, menu's are all there, recordings not accessible,but Netflix loads and plays as normal, ???
Message posted on 20 Oct 2025 09:32 PM
Re: Sky q mini box blue screen
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
