Discussion topic: Sky q goes off
This message was authored by: Johni512
Sky q goes off
Sky q box goes off while watching live tv or recorded program. Done everything as per sky help
Re: Sky q goes off
Hi @Johni512
Have you Reset Settings in the Q box hidden menu.
Avatar for Johni512
Re: Sky q goes off
Thanks. Already did that. Still the same.
