Discussion topic: Sky q connectivity issue
Message posted on 05 May 2026 12:56 PM
Sky Q suddenly not connecting to non-sky internet. I have tried all the suggestions on the line. Any suggestions?
Message posted on 05 May 2026 01:55 PM
Re: Sky q connectivity issue
Hi @Frustra1
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 05 May 2026 02:02 PM
Tried all that, still didn't connect.
Message posted on 08 May 2026 09:08 PM
I'm having exactly the same issue, I rang Sky, the chap I spoke to was baffled so sent a new Sky Q box. Tried to install....won't connect to broadband. Continually says my password is incorrect, despite it being right. I've also updated the software on the Q box, still nothing. I'm worse off now as the new box needs to be paired with the viewing card.....which needs broadband, so can't watch anything at all. I'm at my wits end. I can't ring up until my days off as I'm working shifts. It's not as good trying to share the football on a iPad!
