Discussion topic: Sky q connect router
This message was authored by: stephenmallon
What cable do I need to connect my sky q box to my Ee router  EE Smart Hub Plus (SH31B)
will I still able to connect to my sky mini box?
Re: Sky q connect router
To connect a SKY Q box to a router via ethernet cable you should probably get a Cat5e cables
If you are connecting a mini via ethernet also then you can connect that to the Router or an unmanaged switch (to provide more ports) on the same network.
The location of an unmanged switch can be anywhere on the network so wherever is physically better for you.
Avatar for stephenmallon
Level 2 icon
Thanks for the quick reply. So I want to connect the main sky q box via Ethernet cable which I'm going to try now. I need to do the sky mini wirelessly, just follow the usual instructions and connect wirelessly for that ? Or as they are already set up wirelessly , I Might not to reset them up?
