Discussion topic: Sky q box
This message was authored by: Powell_e1
Sky q box
Box keeps getting signal interruption only stops if we un plug and restart last a week or so then does the same
Re: Sky q box
Hi @Powell_e1
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers which includes additional help from customers who are Superusers like myself.
”No signal” messages tend to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you are seeing a ”No satellite signal” related message, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️it is currently raining very heavily (in which case see if it returns to normal when it eases.)
So check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
Additionally:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
