Discussion topic: Sky q box
Message posted on 18 Oct 2025 06:39 PM
Sky q box
Message posted on 18 Oct 2025 06:47 PM - last edited: 18 Oct 2025 06:48 PM
Re: Sky q box
@GUINNESSGIRL wrote:
Why is it asking me to insert card to watch anything
@GUINNESSGIRL has your viewing card popped out at all if not try taking it out and giving the chip a clean with a soft lint free cloth and re-insert the card
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 18 Oct 2025 06:55 PM
Re: Sky q box
Hi @GUINNESSGIRL Put in the exact wording Here.
Message posted on 18 Oct 2025 07:01 PM
Re: Sky q box
Sky q box doesn't have a card does it? I thought that was old boxes
Message posted on 18 Oct 2025 07:08 PM
Re: Sky q box
Q minis don't have viewing card; only the main Q box has.
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
