Discussion topic: Sky q box
This message was authored by: Robertcarsson
Sky q box
Our sky q box keeps freezing mid programs .... other times won't turn on ... ive unplugged it left it off overnight and done all the usual requests ... disconnected everything left it 5minutes .... reconnected still won't turn on .... then randomly it will turn on
Re: Sky q box
Hi @Robertcarsson
