Discussion topic: Sky q box
Message posted on 25 Mar 2023 01:51 PM
Sky q box
My sky q mini box is showing technical fault on it them main sky q box is working but the one up stairs isnt
Message posted on 25 Mar 2023 01:53 PM
Re: Sky q box
Hi @Calador
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 25 Mar 2023 02:17 PM
Re: Sky q box
I've done all that and sky q mini is still saying programme unavailable on every channel
Message posted on 25 Mar 2023 02:22 PM
Re: Sky q box
It's saying on the screen up stairs please check your subscription entitles you to view this channel on this box that's on all the channels but the sky q main box is working down stairs I've gone on setting s on mini box and it's saying it's connected to sky q main box and connected to internet
Message posted on 25 Mar 2023 04:28 PM
Re: Sky q box
@Calador if you press home scroll to settings and enter in the status page does the bottom entry "watch on sky mini box" have a tick against it ? If not scroll across then scroll down to that entry and vlivk on re-activate
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
