Discussion topic: Sky q box
Message posted on 30 Sep 2026 07:25 PM
Sky q box
My Sky Q box won't record anything the red light come on but it for not record anything
Message posted on 30 Sep 2026 08:14 PM
Re: Sky q box
Hi @sue17011972
You may have Hard disk issues.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
