2
This discussion topic has been answered Discussion topic: Sky q box won’t stay on
This message was authored by: Canders
Sky Q box went into standby without any input. Turned on again and it stays on for a few moments before going into standby again. Has happened several times in a row.
Avatar for Canders
This message was authored by: Canders Answer
Re: Sky q box won’t stay on
Hi Oldfella,
Thanks for taking the time to provide an answer to my problem. I tried your suggestion but the problem persisted.
I turned my attention to my TV, a Samsung frame. It turned out the tv was shutting my sky down. After a couple of days research and much frustration trying to get the tv to stay on. I found an article suggesting taking the batteries out of the smart remote. This cured all the problems. The sky remote has since packed up all together. But we use the sky remote for most things anyway.
So the sky problem was purely caused by external issues.
once again thanks for your help.
Hi @Canders
While it is on try a Reset Settings in the Q box hidden menu.
Avatar for Canders
Hi Oldfella,
Answered - Go to Answer
