3
This discussion topic has been answered Discussion topic: Sky q box will not respond to the remote, batteries are good the remote controls the tv ok
This message was authored by: Beachy
The remote batteries are good and it lights up when I press ?. The sky box will not respond to the remote although the tv will respond. I have turned everything off including the router.
Re: Sky q box will not respond to the remote, batteries are good the remote controls the tv ok
Hi @Beachy
Try completly resetting your Bluetooth remote.
Hi @Beachy
Avatar for Beachy
Thank you I'm up and running again.
This message was authored by: nopic
7 and 9 flashes but 1 and 3 don't
