Discussion topic: Sky q box problems
Message posted on 04 Dec 2025 07:11 AM
Sky q box problems
Message posted on 04 Dec 2025 10:52 AM
Re: Sky q box problems
@wgg1848 wrote:
Our sky Q box keeps cycling off and on every minute or so. I have tried all suggestions from sky. The tv works perfectly when disconnected from sky. Do I need a replacement sky q box and if so how do I get one ?
Hi @wgg1848
Failing this
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
