Discussion topic: Sky Q mini box
This message was authored by: Discovery26
Sky Q mini box
I need a contact number for an engineer
Re: Sky Q mini box
What issue are you having with the mini box that makes you suspect you need an engineer visit?
Avatar for Discovery26
Re: Sky Q mini box
We had a power cut on Tuesday and when the electric came on, the main Q box came on but the mini box didn't. We've tried resetting it and done many of the options but nothing has worked.
We've been advised through the Sky app that we need an engineer/technician but no contact number given.
Re: Sky Q mini box
Typically they'd just offer a hardware swap-out by courier delivery: there aren't any field repairs applicable to Mini boxes.
Re: Sky Q mini box
@Discovery26
Any power light on the mini box?
Have you tried it in another plug socket?
Have you tried a different electrical device in the socket the mini box is in?
As stated by @TimmyBGood Sky are far more likely to just arrange what is known as a doorstep box swap whereby DPD deliver a replacement mini box and take away your mini box that you'll have to disconnect and have ready by the front door for the courier.
These are the current methods for contacting Sky. Depending on the reason for making contact some methods will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Re: Sky Q mini box
Hi @Discovery26
Work through the following link.   It also refers to mini boxes.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
