Discussion topic: Sky q box on wall
This message was authored by: Samja
Message posted on 28 Apr 2023 09:12 AM
Sky q box on wall
I want to put my tv and sky box up on a bracket on the wall, I think I need the sky cable extended, do sky do this or can you buy longer cables/extensions? TIA
This message was authored by: bob1234
Find out more
Message posted on 28 Apr 2023 10:06 AM
Re: Sky q box on wall
@SamjaSky don't do them but you can buy them from Amazon etc
You need to search for, Satellite extension kit and an HDMI lead the length you want, longer mains leads are also available (figure of 8 plug)
You are a bit stuck with the mains lead if you have a V2 box with the separate power unit.
