Discussion topic: Sky q box not working
This message was authored by: AEBF
My sky Q box keeps rebooting and going off
Re: Sky q box not working
Hi @AEBF
Avatar for AEBF
tried all that
Avatar for AEBF
You can't access any of it the box doesn't come on at all
Hi @AEBF
Have you tried pressing the standby button on the front right of the box (Amber led)?
If this brings the box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for AEBF
No that didn't do anything
Hi @AEBF
Try the recovery procedure in the following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Avatar for AEBF
Yes we did all that before trying to make contact
Hi @AEBF
If you have been completely through the link I posted and cannot solve your issue then you need a replacement Q box.
Avatar for AEBF
How do I get one ?
@AEBF wrote:
How do I get one ?
Contact Sky @AEBF
