Discussion topic: Sky q box not on network
Message posted on 02 Dec 2025 12:18 PM
Error on screen saying .. there has been a problem finding your sky q box on the network.
all system status's are ok
QR code checks done. Also ok.
Message posted on 02 Dec 2025 12:44 PM
Re: Sky q box not on network
Is this on a Q Mini box @sureshsandy
If it is
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
