Discussion topic: Sky q box freezing everyday
This message was authored by: Roverdog27
Every morning our sky q box is frozen in standby and we have to unplug and restart it every morning, and new it freezes when we try and switch it on in the evening as well.
Re: Sky q box freezing everyday
Hi @Roverdog27
Avatar for Roverdog27
Done all this, and still no difference. In fact we now have the added error, of sound but just a black screen. As I understand it I do not own the sky q box, so how do I report this?
This message was authored by: mr.tickle
Based on your wording, I have a hunch that what you are describing is a known bug.
Please try this work-around next time it happens: instead of using the remote control to bring the box out of standby, physically press the button on the front panel to bring it out of standby (the one with an orange light in the middle of it which will then turn green). There's no need to power-cycle the box if this works, and it's already been reported and we are awaiting newer firmware to fix it. Then carry on using the remote as normal.
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
