Discussion topic: Sky q box drops internet connection to Bt hub. Also Ethernet connection does not work
Message posted on 31 Jan 2024 07:57 PM
BT hub is connected to internet. Sky q WiFi connection dropping out and not auto reconnecting. Tried hardwiring using Ethernet but doesn't work
Message posted on 31 Jan 2024 08:18 PM
Re: Sky q box drops internet connection to Bt hub. Also Ethernet connection does not work
Hi @PhilWales
When Q boxes are connected by Ethernet you can then switch off all Q box WiFi.
(provided you have no mini boxes on WiFi)
On the main Q box first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router. Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
Provided you have no mini boxes on WiFi as soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
