24 Nov 2023 02:14 PM
I'm having this issue. Says press the dot then press and hold the the arrows until it flashes but it's already flashing before I can press it?
27 Nov 2023 10:33 PM
Been having this same issue for 2 weeks now. No idea why it's suddenly stopped connecting.
28 Nov 2023 08:38 AM
@Bunnyrabbit1981 wrote:I'm having this issue. Says press the dot then press and hold the the arrows until it flashes but it's already flashing before I can press it?
Well if it's flashing it's trying to set up a WPS connection so just go and press the WPS button on the router (or booster if applicable)
28 Nov 2023 08:39 AM
@Stebbsy wrote:Been having this same issue for 2 weeks now. No idea why it's suddenly stopped connecting.
Someone on another thread said pressing the reset button on the back of the Sky router worked (and behaved differently from a power off/on)
28 Nov 2023 06:35 PM
This issue has now happened to us ....live TV works mini boxes not working ...all streaming services work through TV so no issue with broadband coming in .. sky Q box just won't connect to router no matter how many times I turn off everything or sit holding the damn WPS router button in! Come on sky ... we pay a fortune each month and this seems to be a common issue HELP!
28 Nov 2023 06:40 PM
@TsusEv wrote:This issue has now happened to us ....live TV works mini boxes not working ...all streaming services work through TV so no issue with broadband coming in .. sky Q box just won't connect to router no matter how many times I turn off everything or sit holding the damn WPS router button in! Come on sky ... we pay a fortune each month and this seems to be a common issue HELP!
Did you read my post right above yours?
26 Dec 2023 03:18 PM
No network connection on newish 2TB Sky Q box. Was working but over the last four weeks it has been dropping off the network. Constant re connection problems but now it will not connect to network at Al by WPS or SSID. we have been left with just basic TV when we tend to stream so very inconvenient.
26 Dec 2023 03:56 PM
@Kitsmum is Sky your broadband provider or is it a third party broad band provider
01 Feb 2024 09:40 AM
We have tried everything
we need a new sky box please
31 May 2024 02:24 PM
When I am trying to go into an app it is telling me that my internet provider is experiencing problems and that I should use a different wifi network.
05 Jun 2024 07:42 AM
@Paule4 wrote:When I am trying to go into an app it is telling me that my internet provider is experiencing problems and that I should use a different wifi network.
Have you tried ethernet, as per this topic's subject, or is this a wifi-only problem, as far as you know?
06 Jun 2024 08:50 AM
Don't pin your hopes hopes on a new main box, had an engineer here yesterday because i was having this problem with my 2 minis, so he changed all 3 boxes, now i have no internet on all 3! with either wifi or ethernet.
