Discussion topic: Sky q box connection
This message was authored by: Gemma209
I joined sky and the engineer had said you have a refurbed box that connects to the back of the areal cables. Ive had my house renovated and now the box (25cm) I cannot use as I would need at least a 10metre cable to go around the room as I have had a change in rooms. Just want to check I wanted to go through Wi-Fi where you would get a smaller flat box and they rang to say I would need to pay 32 upfront and an extra 11quid a month o top. Is this right or am I been fobbed off?
Re: Sky q box connection
You can switch from Q to Stream - it's quite a different product.  In regards to the price I'm suprised at that increase - try calling a different agent.
Avatar for Gemma209
Yeah I will ring up and double check the price is right to go to Wi-Fi I need any other packages just the regular sky channels
thanks
