Discussion topic: Sky q box and mini box
This message was authored by: Dexibeau
main box and mini box’s are not working properly, on demand or recordings won’t work at all and normal Chanel's keep glitching. This has been going on all week despite me trying to reset as previously advised.
Re: Sky q box and mini box
@Dexibeau Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Dexibeau
Regarding on Demand first try rebooting your router.   To reboot disconnect the power lead for 30 sec then reconnect.
Wait until the router is completely back up and running and then reboot your Q box.
If you still Have an issue with on demand Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
