Discussion topic: Sky q and mini boxes
Message posted on 08 Dec 2025 05:26 PM
The connections on both main box and mini boxes keeps going to blue screen. I have been in touch with BT and no broadband issues.
Main sky box keeps running and is noisy. Suspect something to do with main box. We have tried multiple reboots.
Message posted on 08 Dec 2025 05:59 PM
Re: Sky q and mini boxes
@Julie298 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 08 Dec 2025 06:01 PM
Sky Q gets it tv signal from you dish outside if you are getting a blue screen on your main box it men's that it losing it signal from this dish. It not affected by loss of WiFi and there fore nothing to do with BT. If the problem persist you need to get in touch with Sky to send out a engineer to look at your dish, to sort the problem out. However If you getting Sky tv on your main dish but losing it on mini box that's because it losing connection to you main box which is by WiFi but not though you internet hub, but direct from your main box. It can usually fixed by going into the settings on you mini box and doing a network onection reset it, if has worked ok up till recently. If that don't work you need again to contact Sky to get the problem sorted.
