Discussion topic: Sky not working
Message posted on 09 Sep 2025 07:57 AM
Sky not working
Sky not working on 2 tvs
Message posted on 09 Sep 2025 07:59 AM
Re: Sky not working
Your other post on a thread about no satellite signal has been removed to prevent duplication of replies.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
