Discussion topic: Sky not working
Message posted on 20 Jun 2023 05:11 PM
Sky not working
Unable to pair viewing card
unable to watch sky sports
unable to record programmes
Message posted on 20 Jun 2023 05:15 PM
Re: Sky not working
First try a reboot if you haven't already
Then
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 20 Jun 2023 05:27 PM
Re: Sky not working
It says viewing card
install not complete
an active broadband connection is required.
Message posted on 20 Jun 2023 05:29 PM
Re: Sky not working
@Michelle+Lawrence Is this a new Q box you've received from Sky? Have you ensured the box is connected to your broadband?
Message posted on 20 Jun 2023 05:31 PM
Re: Sky not working
Yes it is
Message posted on 20 Jun 2023 05:35 PM
Re: Sky not working
The last messages is sugesting it's not getting a broadband connection.
I would power down the Q box by removing the plug from the wall, unplug the hub, plug the hub back in, once up & running plug the Sky Q box back in.
