Discussion topic: Sky multi room missing apps
This message was authored by Bikerboy62 This message was authored by: Bikerboy62
I have all the apps on the Sky Q box but with multi room viewing some of the apps are missing. ITVX and paramount being the obvious two.
Anyone found this issue and if so how did you resolve it ?
Re: Sky multi room missing apps
Hi @Bikerboy62
Reboot the mini as above.
Bikerboy62
I have tried the reboot process twice now -it doesnt make any changes to the apps
Hi @Bikerboy62
Try a Reset Settings in the mini box hidden menu.
This message was authored by stereohaven This message was authored by: stereohaven
Hi @Bikerboy62
Try refreshing the apps on the mini box:
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
LG B6 OLED 55” | LG UP75 LCD 43” | Sky Q | Sky Q Mini | Apple TV 4K | SONOS Beam 2 | Sky Mobile | FTTC BT Halo 3+
This message was authored by hughes27 This message was authored by: hughes27
I keep getting the message " there was a problem refreshing your apps" no matter what I try. Sky Q main box rebooted and mini box rebooted multiple times.
This message was authored by Griffo69 This message was authored by: Griffo69
After reading multiple posts about missing apps on skyq mini boxes can I please say one thing, "Make sure the box has the latest software version installed". When the software is up to date just go through the app update and everything should be ok and all your apps will appear, good luck.
